D17 wide front swap
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Topic: D17 wide front swap
    Posted: 18 Mar 2011 at 5:39pm
Series III and IV had the same wide front.  I'm looking for one as well to replace the diesel Series I/II wide front that was adapted to my Series III gas.  It originally was a NF.
Should be no problem running your loader through the remotes assuming your Series IV is equipped with two remotes (mine only has one).  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
roadrunner(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roadrunner(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 4:59pm
Is the wide front the same on series III and series IV? Looking at a series III parts tractor. My series IV has a narrow front and would like to switch. Second question is will a 415 loader work fine with my series IV by plugging hydraulics into tractor, instead of front pump?
