D17 water pump
alc609 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Topic: D17 water pump
    Posted: 03 Oct 2011 at 5:44pm
Got my d17 out today to get ready to rake hay and noticed a noise in the front , maybe water pump. Can you grease them or do you need to rebuild them?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 9:27pm
They are sealed bearings, and you can rebuild them, but it is almost not worth it, if you do rebuild them, you need to be very careful about getting it right.  I would make sure it is not something else, run it for a few moments with the fan belt off.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 9:53pm
Has a bearing sound to it but don't do it at low rpm's only other could be alternator or pump
