d17 tires
donais View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Topic: d17 tires
    Posted: 12 Jan 2012 at 10:31pm
i currently have 18.9x28 tires on this ans i found some almost new 14.9x28 tires for 100 each will they fit on this rim?  the rim is @ 14.5 to 15 inches wide. thanks    jon
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 10:33pm
Yes, they will fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 10:43pm
sweet, also does anyone have a pic of where the steering shaft goes into the bell housing on a diesel i need to make a bushing!!
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 10:48pm
There is supposed to be a support bushing bearing bolted inside of the left frame rail with 1 bolt just in front of the bell housing. This takes care of supporting the rear section of the shaft. This is likely worn and is letting the shaft rub the bell housing.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 11:45pm
cool thanks i saw that in there guess i get to adjust it
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 5:10am
On the D-17 diesel that I am currently restoring, the shaft and support bearing block was worn. I cut the worn part of the shaft out, drilled, pinned , welded and turned the shaft new, then we made a new support block with a brass wear bushing.Also drilled and tapped the block for a grease zerk. She won't wear out again in my ownership life.  Dave.
