D17 Tie Rod Problems
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Tie Rod Problems
    Posted: 22 Apr 2018 at 4:45pm
So today I changed the front tires and rims on my D17iv and i replaces the worn old tie rods completely (inners and outers). I got everything put in tightened up and ready to go. I turned the steering wheel and the tie rods slipped inside of each other, I figured I didn’t tighten them enough so I tightened them some more and well two sets of bolts later I still can’t get them right enough to keep from slipping. I bought the tie rods as a set so they are the right pair for each other. Any thoughts? I went up in tire size from 6-16 to 7.50-16 does that matter in this issue?
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 5:10pm
I had the same problem on my 190. The biggest problem with the aftermarket tie rods is that the clamp is too small. I took the clamps off of the original set and used them.
The rods also fit too loose in the tube making it difficult to clamp.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 7:44pm
Do as Joe says, I think the old ones are spot wielded on. Grind the little weld off and put on your new tie rods. The new tie rod clamps wont hold if you put antiseeze on the rods. I left both clamps on mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 7:53pm
Poor specifications and quality control. They don't make things as good as they once did. Disapprove
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 8:00pm
Just like Joe said. Use the clamps off the old tubes.
Thanks & God Bless
Dennis
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 8:10pm
This happened with my D15 II some time ago.  New inners and outers and getting the spacing and toe-in set, I spot welded on top so I could change it
Edited by JoeO(CMO) - 22 Apr 2018 at 8:13pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 8:22pm
Do what Joe(TX) did and use both clamps.     MACK
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 10:48pm
Had the same problem on our Series IV D17. As others have said, use the clamps that were factory original to the tractor...they will stay tight.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 5:49am
I had the same problem working on a red tractor, same poor quality just different color paint.
This page was generated in 0.069 seconds.
