D17 tach question
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: D17 tach question
    Posted: 09 Jun 2011 at 12:04pm
i put a new tach and cable on my 17 . if i put the cable in the tach drive (distributor side) first and line up the key thats on the cable with the drive then put it in the tach it willonly work for a little while and then the key slides out of the drive. i can take it apart and put the key in the drive and not even an hour it comes back out. my question is ,is there a part that goes in the back of the tach and the cable goes in to space it out a little bit? this part would have to have o female and male square on it?
 thanks Shawn
190XT,D17and 7045
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 12:17pm
On my series II there is a little plastic do hicky that goes on the drive and the cable sticks into.  The tack end if I remember right just goes into the tach.  Then you just screw them down.  The plastic piece is a very pricey piece.   Got mine at Agco.
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 12:23pm
well Jim i looked into that with Brenda at sandy lake imp. and she sent me two different pieces but  they are if you dont have the key on the cable and mine does so they wont work
190XT,D17and 7045
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 1:11pm
Sounds to me like the cable core is to short for some reason!
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 1:33pm
it measures 52 1/2 like i was told by sandy lake  thats why this dont make sence to me.
190XT,D17and 7045
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 3:41pm
Sounds like inner cable is to short or the outer to long. The ones we sell for the D17 are 56" long and have the metal key crimped on one end. the dist end will accept about 3/4" and the tach end about 1/2". David www.djstractorparts.intuitwebsites.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 6:37pm
You have me looking now. I got out a new cable made by KC speedometer. The end with tang will not recede into housing. A nylon washer makes it stick out about 3/4 inch. The tact end sticks out 1/2 inch. If washer is missing cable could work in to tack.
