D-17 steel fuel line
Doug-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug-KS Quote  Post ReplyReply Direct Link To This Post Topic: D-17 steel fuel line
    Posted: 24 Nov 2017 at 8:44am
Does anyone know where to get a steel fuel line for a series 2 D-17? Or does anyone have a good used one they want to sell? I searched on line and I see them for a bunch of other models, but not D-17.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2017 at 9:40am
Why not use steel brake line, bend to suit, with proper pipe connectors?
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2017 at 9:45am
That's what I used on mine worked good need a brake line tool for the Ferrell
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2017 at 10:39am
Check with Steve in NJ -
B&B Custom Circuits
11 Woodfield Road
Andover, New Jersey 07821
Phone: (973) 632-5596
customcircuits@gmail.com
http://www.bb-customcircuits.com/
Edited by Hubert (Ga)engine7 - 24 Nov 2017 at 10:41am
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 8:08am
I just replaced mine, used steel brake line.  Looks really nice!
gerkendave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 8:53pm
I used a soft copper tubing so you can hand form it from Napa. Then used compression fittings to attach both ends. Looks nice imo
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 8:49am
Steel is harder to work with but better to use in this application.  Copper does not stand up well with the vibration.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 8:51am
Compression fittings.
I have serviced a lot oil fired furnaces over the years. They use 3/8" soft copper to feed fuel oil from tank to gun, then 1/4 or 1/8" soft copper from pump to nozzle.
I have found that using compression fittings with ferrels have a tendency to leak after they have been taken apart a couple of times.
Flare fittings hold up much better.
Dusty
