D17 Spark Plugs
Todd44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd44 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Spark Plugs
    Posted: 13 Jun 2012 at 2:02pm
I am changing the spark plugs on a D17 series IV with a serial no. 76428.  The plugs that I am taking out are champions with a 3/8" thread length.  When I look in the shop manual that my grandpa has for his D17 series IV it calls for 3/4" thread length either: Champion N-8, Auto Lite AG-5, or AC 45XL.  If anyone could help out and know what plugs work out that would be great!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:27pm
Ngk bp5es
Edited by mlpankey - 13 Jun 2012 at 8:59pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:36pm
Check the thread depth in the head. You don't want plugs longer than the threads.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:46pm
Gerald J.
why is that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd44 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:47pm
The thread length in the head is 3/4", but the plugs that the original owner used were 3/8".  Now the threads that were exposed are filled with carbon.  So I don't know if I should run a spark plug thread chaser through it and put the longer plugs in or just replace the plugs with the same that I pulled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:54pm
s use the longest reach plug you can without mashing the electrode if looking for performance
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 5:35pm
AC 45 XL
"Burgie"
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 8:29pm
When we sold them we were very pleased with AC plugs.  The AC45, AC47, and AC48.  However, that was some 50 years ago.  I hear that the Auto Lights are now the plug.  Contact Steve NJ.  He has the correct numbers.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 8:43pm
If you're using a 3/8 reach spark plug, the 295 Autolite's are 3/8 reach. If you're supposed to be using the 3/4 reach plug, then the Autolite 64 is the number you want to use. Unless it's an LPG version where you would use Autolite 2594.   HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 10:02pm
You don't want threads exposed in the cylinder for a couple reasons. First the threads can get to glowing and so make shutting down by turning off the ignition not work. Then the exposed threads can get covered in carbon and make it unreasonably hard to extract the plugs (like plugs breaking instead of coming out and penetrating oil won't help).
You can make any old 3/4" reach plug into a carbon cleaning tap by grinding a notch into the leading threads with the corner of a grinding wheel, or with a cutoff wheel. You'd like one face, the one that would cut while turning clockwise, to be nearly perpendicular to the thread so it cuts more than mashes. Or you can find taps for spark plug threads that are mostly metric and unique to spark plugs since the early 20th century.
Short reach plugs put the spark in the spark plug hole, not exposed to the whole mixture and should hurt performance and fuel economy.
Gerald J.
Edited by Gerald J. - 13 Jun 2012 at 10:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 7:22am
The plugs exposed threads will never get hotter than the ground strap if ignition timming is set properly. Carbon could be a problem if plugs dont get changed out in a couple of years .
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 8:41am
Originally posted by mlpankey mlpankey wrote:
Carbon could be a problem .
No,  carbon WILL be a problem with removal, there is no "if" about it.
  Life is differant in the work field than on the playing track. Sometimes knowledge crosses over, sometimes it doesn't. Here it doesn't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 9:21am
I have never had a problem with removing plugs due to carbon. I change plugs once a year and remove them and read them often in the field throughout the year.  At the track they get read every time its at a track which lately means the ones in the field get looked at more. pet pev i guess
Edited by mlpankey - 14 Jun 2012 at 9:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd44 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 11:23am
Most of my resoucres that I have contacted have recommended using an Autolite 405 or 64.  Does anyone know, which one would be better than the other?  Thank you for all the great advice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 2:32pm
I use the 405s in ours and they work fine
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 6:14pm
I have used autolite 64's in my D-17 ser.3 for years with no problems at all. Personally,I think autolite is the best plug out there. I use them in every gas engine I own.
This page was generated in 0.975 seconds.
