D17 serries 1 and D15 serries 1 question
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Topic: D17 serries 1 and D15 serries 1 question
    Posted: 2 hours 33 minutes ago at 12:41pm
I have a D17 serries 1 with power steering. I broke the front casting where the pin that holds the front end on fits. Not to suprised it was worn badly and I put my loader from the D15 on the D17 last summer when the D15 had a blown motor.
My question is the D15 serries 1 has a good front counter weight i know it is tight I had it sleeved a decade ago when I rebuilt the tractor. I know I can not swap the entire counter weight but can I split the weight and swap just the bottom part with the broken casting? I know the D17 weight is taller the bolt spacing on the frame rails makes that clear. I am just hoping maybe the bottom section of the casting is the same part? Both tractors are pretty much stuck in the snow at the moment not real easy to work pn but I am trying to come up with a plan or figure out if I need to be looking for a parts tractor.
