D17 series one lift arm problems. Please help
Devin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Devin Quote  Post ReplyReply Direct Link To This Post Topic: D17 series one lift arm problems. Please help
    Posted: 9 hours 32 minutes ago at 9:46pm
Hello, working on a family members d17 series 1 and looking for some knowledge. Any time the engine is running the lift arms raise like there's pressure going to them regardless of where the controll lever is set at. The linkage for the traction booster is unhooked and I made sure the rod at the bottom of the tractor is not hanging up and causing troubles. If I shut the tractor off the lift arms will drop but will not while tractor is running. The hydraulic lever will make them raise faster when moved but when it's at the lower setting they still creep up. Wondering if I have a valve leaking by or something else? Any help would be greatly appreciated, thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 27 minutes ago at 9:51pm
The Traction Booster rod under the belly MUST BE HOOKED UP and adjust the nuts FORWARD as far as they can go for now. Traction Booster lever must be down/horizontal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Devin Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 7 minutes ago at 10:11pm
I forgot to mention traction booster has been unhooked as long as he's owned the tractor but the lift arm problem started recently and has progressively gotten worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 3 minutes ago at 10:15pm
Don't argue. Hook it back up and adjust the nuts FORWARD and then report back if it doesn't work. T.B. lever must be DOWN/HORIZONTAL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Devin Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 55 minutes ago at 10:23pm
No arguing here just trying to give all the info I can. I will do what you recommend first. Thank you!
This page was generated in 0.238 seconds.
