D17 SERIES IV
ohiogoatman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ohiogoatman Quote  Post ReplyReply Direct Link To This Post Topic: D17 SERIES IV
    Posted: 23 Sep 2010 at 12:19am
Good Evening.
I recently purchased a 1960's model D17 sesries IV and am curious as to the potential. I got it primarily for the PTO to run my grain auger. It is doing wonderfull. What other sizes of equiptment can i pull through the field with it? plow disk planter etc?
any info would be great. i don't want to try and end up damageing this piece of equiptment.
i live in north west ohio with easy soil and flat no terraceing or anything like that just flat.
thanks
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 7:32am
I pull a 4 bottom plow with mine. It should also handle a 12 foot disc or field cultivator easily. You have arounf 52 horsepower at your disposal, so as you shop for implements and tools that is the number you are working with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 3:01pm
I totally agree with what John said unless you are are pulling that disc or FC in moldboard plowed ground.  Then it's a 10 foot disc or FC that's a good match.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 3:17pm
Depends on the soil and the width of the plow bottoms. 4x12 maybe, 4x 18, I'm sure not with 52 HP unless its in sand. In my field no way unless in first gear. And I found that pulling a smaller plow faster I got more done and the plowing job was better.
Gerald J.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 3:30pm
My 1958 D17 does real well with a fully mounted 4x14 plow in 2nd low range in black dirt with some spots of blue clay. Although the engine doesn't lug I feel that 3x16 would be more comfortable and you could plow in 3rd high. But it is fun to go plowing 9" deep with a 4x14 and show up the 880 Olivers and 720 John Deeres.
Wink
I am a Russian Bot
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 6:26pm
we pull a 6 row 7000 deere planter and a 316 new holland square baler with ours.
