D17 Series IV
Missouri Mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Missouri Mike Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV
    Posted: 11 May 2010 at 7:45am
Have recently purchased D17 Series IV and need parts.
Would consider a donor tractor. Located in Mid Missouri if you have anything please contact me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 12:06pm
Mike - not too many Series IV's get parted out given they are the most valuable of the D17's (Wheatland's being a special case).  It would help if you gave us a more detailed list of what parts you are looking for.  But one suggestion is Cook Tractor in Clinton, MO which is close to you and they have a pretty good salvage yard with a fair amount of AC in it.
BTW - I still farm in Pilot Grove, MO not far from you and I also have a Series IV - great tractor.  Mike
Edited by Skyhighballoon(MO) - 11 May 2010 at 1:21pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 12:08pm
170/175 has some parts in common.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Missouri Mike Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 11:04am
Need Front end parts. Wishbone, Steering arm, Power steering pump,
possibly front casting for wishbone. That is it for now.
Thanks
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 12:21pm
Mike - D17 Series III will also have all those parts in common.  Not for sure but thought the the D19 also used the same Barnes type power steering pump driven off a 2nd belt from the crank pulley.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
