D17 Series IV Power Steering Belt |
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1161 |
Topic: D17 Series IV Power Steering BeltPosted: 06 Sep 2023 at 10:12pm |
I noticed the power steering belt on my D17 Series IV is cracked in several places. I'm guessing I should replace this before it breaks. Has anyone ever replaced one of these before? Just curious on the difficulty and any past stories encountered. As always, thanks in advance!
MACK
Posted: 06 Sep 2023 at 11:05pm |
Only problem is it is a close fit between front pully and front support but it will go. MACK
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
Posted: 07 Sep 2023 at 10:10pm |
Well....
looseing the PS pump bolts can be challenging..... and that's how you tighten/loosen the belt. Make sure you have quality angel wrenches on hand. Not much turning radius on one of those bolts. Best of luck. Finesse not force !!! |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
Posted: 08 Sep 2023 at 2:45am |
Just adjusted/ tightened my series III. no issues if the bolts are not seized!
Blue Skies and Tail Winds
Dana |
Posted: 08 Sep 2023 at 6:32am |
Those bolt heads are best worked on with a good quality open-end 9/16" wrench that has WIDE tangs. A cheap narrow wrench doesn't make full use of the head of the bolt, especially if the last guy used a cheap wrench and has rounded off the bolt heads a bit.
