D-17 Series IV Plumbing
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Series IV Plumbing
    Posted: 12 Mar 2017 at 12:59pm
Looking to add a 2 spool valve to run the loader and keep my remote open on the tractor. I should be able to put a T in the line coming off the pump and going to the remote valves correct? from the T I would put a quick coupler on it.
Now for the return I should be able to put a T with a nipple on it into where the drain is for the sump, with a quick coupler on the T, and with a plug on the bottom to let me still drain the sump.
This is the right way to go about it right?
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 1:11pm
Ran ours in series with the existing remotes and added a separate loader remote. Thus did not change the use of the existing hydraulics (3 pt and hydraulics for equipment).
Edited by Stan R - 12 Mar 2017 at 1:13pm
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 1:40pm
If you put a T inline you have to have a closed center valve system I think your tractor has open center valves so you have to put the new valve in serries with the current valves. Think of it as a water hose you put your finger over the end of the hose to make pressure to hit shameless on the other side of the room. Now desert Joe seeks in and puts a T in line thinking he will soak you. Well since the water just flows out the other side of the T with no pressure restriction shameless sits on the other side of the room dry laughing at both of you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 2:06pm
Forgot about the D-17 being open center. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 3:34pm
Can't help you Mike with the problem, but here you JUST GOT a new toy and right away you want to change it and make it better........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 3:36pm
You say that like there is something wrong with it?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 3:58pm
Got to make it usable. It isn't helping me make money just sitting there! Lol
This page was generated in 0.115 seconds.
