D17 Series IV lift shaft seals
vaAllis90 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vaAllis90 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV lift shaft seals
    Posted: 15 Jul 2017 at 7:25pm
My lift shaft seals are leaking on my Series IV and I am trying to figure out the best way to replace them. What has to be removed/ what is the correct order of removal to replace these o-rings? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 8:56pm
Do you mean the seals in the lift arms?
bigmoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigmoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 9:44pm
If you're talking about the lift cylinders, it's a known problem. Rebuilt mine once and it started leaking again so decided to replace them with cylinders off a 175.
64 D17 IV
50 WD
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 7:19am
Remove both lift arms, slide shaft to left then replace right orang, do same to other side. Be good time to replace shaft bushings.    MACK
