D17 series III
cougar766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cougar766 Quote  Post ReplyReply Direct Link To This Post Topic: D17 series III
    Posted: 12 Sep 2010 at 7:50am
got a D17 Series III in at the shop and need to know if it is supposed to be neg or pos ground, also if anybody has a good wiring diagram. I've got too rewire it as the wiring is shot and its not charging at all. Thanks in advance folks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 8:18am
To see how it was last set up., look at the coil. If the neg side of the coil goes to the distributor it is neg ground. If the pos side of the coil goes to distributor, it is pos. ground.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 8:21am
I believe all D-17s, right thru the series IVs have positive ground systems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 8:23am
Actually, I like Charle's answer better, cause you never know what might have been done to the system over the years.
