D-17 series 4 wide front question |
Josh Day
Topic: D-17 series 4 wide front questionPosted: 04 Feb 2017 at 2:12pm |
Hello all, I'm going to be rebuilding the wide front on my 17, what's the best way to get the steering arms off of the spindle in order to pull spindle from spindle housing? Thanks! Josh
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10876 |
Posted: 04 Feb 2017 at 2:51pm |
The arm has to come off the spindle, you can't drive the spindle thru arm and housing. First remove snap ring,arm comes off from top, remove key and spindle should slide out. A little heat will help.HTH
MACK
Posted: 05 Feb 2017 at 8:59pm |
Pull the axel out, turn up side down, slide axel back in. Now you can take a big sledge hammer and beat down on it. Good luck. MACK
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 05 Feb 2017 at 9:51pm |
X2. |
