D17 Series 4 spark plug confusion |
Rusty Allis
Bronze Level Access
Joined: 16 Jul 2020 Location: Rhode Island Points: 176 |
Topic: D17 Series 4 spark plug confusionPosted: 20 Sep 2025 at 9:54pm |
Well...
Long story short is I had to pull a plug and noticed that it had Champions (yuck) in it but the plug was a short reach RJ12C plug. I did find this thread: D17 Spark Plugs - AllisChalmers Forum But...it seemed to kind of trail off without any definitive answer. The threads are LOT longer, so after some digging it looks like I need the long reach plugs. 1) am I correct thinking it really should have the long reach plugs in it and 2) will NGK BP5ES be ok? and..."while I'm there" can anyone suggest a good set of wires? Delco? Bosch? Thanks!
KJCHRIS
Posted: 20 Sep 2025 at 11:04pm |
we find both short and long reach plugs in them. In theory early D17 will be short 3/8" thread (Autolite 295) and later will be long reach 3/4" thread (Autolite 405). The split is tractor at s/n 75000 / 75001. BUT as D17's are 60+ yrs old you can find some have been pieced back together.
Always check the heads thread depth to verify which length plug it should have.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1589 |
Posted: 21 Sep 2025 at 9:00am |
Champions will work just fine! Lol.. So will the NGK. Or any plug you can find of the correct heat range. Mine ran all its life on used plugs out of our Camaro's and Chevelles. And ran well and still is 60 years later!!
Rusty Allis
Bronze Level Access
Posted: 21 Sep 2025 at 6:27pm |
This does in fact have longer plug threads than the plugs in there now and I'll need to chase the threads.
I didn't measure, but they look about 3/4" long. I'll order a set of NGK's and see what happens
