D17 series 4 oil pressure gauge
Bob (mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (mo) Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 4 oil pressure gauge
    Posted: 03 Jul 2020 at 11:03pm
I just installed a new 80lb. Allis oil pressure gauge on my series 4 D17 and out of the box the needle was pegged all the way to the right I messed around with the inlet fitting on the back and got the needle to the zero or the beginning position so I went ahead and installed it and the needle only raises to N and some times to the O is this about right or is the gauge faulty? the old probably original gauge I removed would go 3/4 to full.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 6:10am
D17 s4 gas only has 32 psi. 80 psi gauge is too big and for a diesel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 9:56am
Doc is correct. I had to put a 80lb on my XT because the only choice was a 30 or 80lb gauge as the XT never had a gauge only an idiot light. So it runs between the O-M. I still have my light plumbed in but the gauge gives me the reassurance if the sending unit goes bad as it did 2 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 10:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 11:01am
AH, Don't you just love that Chinese aftermarket crapCry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (mo) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 5:25pm
I dont know why I thought I needed a 80 pounder but seeing how its faulty and gona have to return it anyway maybe Djs will let me exchange it for a 30 lb. Thanks for the input everyone.
This page was generated in 0.227 seconds.
