d17 series 4 live hydraulics?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: d17 series 4 live hydraulics?
    Posted: 07 Jan 2011 at 9:13pm
Can someone explain to me how the hydraulics still work on a D17 series 4 when the clutch is pushed in.   I know things were designed different for this, but I don't have a manual that shows a breakdown of it.    Got my loader on this past weekend and got a chance to tinker and drive around last night and thought it was awesome that I could still move the loader and disengage the clutch.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 9:24pm
On SerIV models the hydraulic pump driven by a hollow drive shaft which is splined into the clutch cover.The bevel gear on the rear end of the hollow drive shaft drives the hydraulic pump all the time the engine is running.
Looked it up in the manual word for word.I never realized how it worked until just now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 9:24pm
Chuck - a hollow quill shaft is driven directly off the flywheel.  Inside the torque tube it's taken off there at the belt pulley location using bevel gears to constantly drive the hydraulic pump as long as the engine is turning.  The regular shaft attached to the clutch turns inside this hollow quill shaft.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 9:25pm
Chuck, The series 4 have a different pressure plate on the clutch assembly. It drives an outer shaft that drives the pump mounted on the side of the tractor all the time. I just wish Allis had put a dual clutch in those tractors for live pto, and still keep the PD. We have a D17 with a Henry loader with a front mount pump. Of all the tractors we have had over the years, this loader has more lifting capacity than them all. That is likely why it came with the original front end in pieces.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 9:26pm
You guys are faster than me on the keyboard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 9:35pm
Thanks guys.   That explains it.   Now I just need to get some bigger meats on the front to handle the loader better and it will be guaranteed to not snow the rest of the winter here in Wisconsin!!
