D17 series 4 hydraulic line |
Putnamd17
Topic: D17 series 4 hydraulic linePosted: Yesterday at 11:30am |
Anyone have a picture of the correct hydraulic lines that run to and from the hydraulic filter can’t seem to get the top line quite right due to the end of it curving up by the brakes.0
Alvin M
Posted: Yesterday at 1:05pm |
AGCO Parts Shows It In the parts look up
Posted: 22 hours 32 minutes ago at 6:17pm |
I would disconnect both brake pedal rods and springs and swing them down out of the way. I might even remove the RH platform. But, regardless, connect the hydraulic tube to the elbow at the brake pedal area first, but leave the nut a turn loose. Then, go to the filter end and connect the other end of the line.
Posted: 21 hours 43 minutes ago at 7:06pm |
Also, a 3/4" open end "line wrench" is a must.
