D17 series 4 hydraulic line
Putnamd17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 4 hydraulic line
    Posted: 9 hours 33 minutes ago at 11:30am
Anyone have a picture of the correct hydraulic lines that run to and from the hydraulic filter can’t seem to get the top line quite right due to the end of it curving up by the brakes.0
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 58 minutes ago at 1:05pm
AGCO Parts Shows It In the parts look up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 46 minutes ago at 6:17pm
I would disconnect both brake pedal rods and springs and swing them down out of the way. I might even remove the RH platform. But, regardless, connect the hydraulic tube to the elbow at the brake pedal area first, but leave the nut a turn loose. Then, go to the filter end and connect the other end of the line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 57 minutes ago at 7:06pm
Also, a 3/4" open end "line wrench" is a must.
