D17 series 4 air filter cover
Putnamd17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 4 air filter cover
    Posted: 3 hours 34 minutes ago at 3:00pm
I went to change the air filter in my d17 and after I removed the screw/bolt the piece covering the air filter fell apart. It seems like a cloth type material not really sure what it is. Anyone know of a place to get a replacement for this.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 55 minutes ago at 3:39pm
Not available anywhere, but not really a problem.  Any air that comes in still passes through the filter, so the engine is still getting clean air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 30 minutes ago at 5:04pm
Would it be possible to make a metal cut out for it and use that instead?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 12 minutes ago at 5:22pm
The idea was the material they made it out of sort of sealed the end of the filter/canister area to force air to enter thru the stack. Cooler and possibly cleaner air that way. You can make it out of what you want but a little flexible would be better function wise. A thin piece of rubber belting would work, and see if it can handle the underhood heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 4 minutes ago at 5:30pm
Ok thank you.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 36 minutes ago at 5:58pm
I bought a replacement from Agco about two years ago. It didn't really look like the original and was made out of a thin rubber material and basically just sealed the end. Ryan
