D17 series 3 governor lower level compensating spr |
PeterinMN ![]() Bronze Level ![]() ![]() Joined: 25 Aug 2025 Location: Albany, MN Points: 12 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Sep 2025 at 8:56pm |
Does anyone have a picture of the governor spring on a d17 series 3? located under the battery, where the throttle cable links to the governor rod. something doesnt seem to be working right with mine. Tractor doesn't want to idle down, and when I throttle up it immediately goes to high rpms. any advice ?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21925 |
That spring isn't causing the problem. I think your governor weights have exploded.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7506 |
x2.
What makes you think so? I was just trying to see if I am possibly missing a part on the spring. One of the rod holders was being held together with baling wire so…keep in mind this was a working tractor on my family’s dairy farm 20 yrs ago so often function was more important than how something looked. I am now trying to piece it back together. Any help is appreciated .
The function of that spring that sits under the gas tank is to make the throttle lever pull down easier when you get half-way down or more. It is an assist to make the linkage work easier. By your own description, the governor weights possibly have exploded. That spring under the gas tank can be missing completely and the engine will still idle down slow and not run away by over revving. My opinion is based on what you have told us and 50 years of D-17 experience.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8640 |
gov wts and pins don't last forever
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
X3.....' happened to my D17 Series 2 a few years ago.
Things do wear out.
I took my governor out and everything looked fine, weights are in place. I put it back together and now it won’t start because I think the timing is off. I followed the procedure outlined in the shop manual starting with finding TDC on the flywheel and positioning the distributor accordingly. No luck. Does the governor shaft and weights have to be put back in place the exact same way they were facing when I took them out? Does this matter? Thanks in advance.
If you mark where the rotor is exactly, remove the whole assembly as you did, reinstall it with the rotor back in the same place and it will fire right up.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3916 |
are you sure you are on tdc 1 not 180 off
According to the shop manual, Top dead center on the flywheel is the solid line with the F on top of it. The F is used for a timing light. The line should line up with the notch on the tractor. At this point the rotor should be pointing at 1 cylinder’s spark plug. It should work, but it’s not it is backfiring.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5026 |
I'm betting your timing is 180 degrees off (like HudCo said).
Since it's a 4-stroke engine, the engine only fires every other revolution. When you are approaching TDC on #1 cylinder (between the compression and power strokes) you will feel compression if you put your finger over the spark plug hole. When you feel compression, start watching for your timing mark again. When you get to the timing mark, you need to take the distributor out, reset the distributor to the #1 position, then reinstall the distributor.
Edited by WF owner - 11 Sep 2025 at 5:44am |
TDC is the flywheel mark you are looking for thru the hole in the right side of the bell housing. F or F-25 or F-30 isn't TDC. The crankshaft pulley setscrew should be pointing dead straight down. Compression should be made on #1 when rotating the engine the way it normally turns. You could be on TDC #4 instead of TDC #1.
got it figured out thank you for the info.
Would be nice to hear what it was....
I thought that F mark on flywheel was Top dead center but as Dr. Allis said it is not. I felt for compression in # 1 cylinder and then kept turning the flywheel until the other mark showed up and that is TDC. Fired right up.
My other over-revving issue I solved by shortening the rod that goes from the carb to the governor vertical shaft. I put it in a vise and made a offset bend in the rod, enough so it fit into the rod holds perfectly with engine off, throttle lever full open and carb throttle shaft pushed all the way back to 4:00 o clock position. I have no idea why the rod was too long in the first place because it is a original part as far as I know but then again who knows? Anyways it runs much better now. |
My next step is trying to figure out why it leaks oil out of exhaust manifold on one of the cylinders, from what I’ve researched it could be piston rings or it could be valve seals or it could be head gasket.
Also, the power steering doesn’t work. Not sure where to start on that one. Winter is coming soon here in MN, and not sure how much I want to tear into this fall. |
Thanks
The original complaint left me with the impression that the problem not idling down and revving way up was a recent thing. In the end, the governor synchronization was wrong and that didn't just happen. It had to have been like that for quite some time. If the tractor was a recent purchase by the poster, that info might have led me down a different path of repair, like start with governor synch first. Exploded governor weights, while the tractor still gets used, can and does cause timing gear carnage that gets expensive to repair. Quick diagnosis of that possibility can save lots of $$$$. I had a governor weight on my WD puller one time split open at the pivot pin hole/lever area. I caught it right away and shut the engine down. All I had to do was replace the broken governor weight. Had I continued to operate it, all the timing gears would have gotten ate up by schrapnel running thru the gear teeth.
Edited by DrAllis - 4 hours 56 minutes ago at 8:14am |
