D17 series 3 governor lower level compensating spr
PeterinMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterinMN Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 3 governor lower level compensating spr
    Posted: 03 Sep 2025 at 8:56pm
Does anyone have a picture of the governor spring on a d17 series 3? located under the battery, where the throttle cable links to the governor rod. something doesnt seem to be working right with mine. Tractor doesn't want to idle down, and when I throttle up it immediately goes to high rpms. any advice ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:28pm
That spring isn't causing the problem. I think your governor weights have exploded.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 3:49pm
x2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterinMN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 6:35pm
What makes you think so? I was just trying to see if I am possibly missing a part on the spring. One of the rod holders was being held together with baling wire so…keep in mind this was a working tractor on my family’s dairy farm 20 yrs ago so often function was more important than how something looked. I am now trying to piece it back together. Any help is appreciated .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 7:14pm
The function of that spring that sits under the gas tank is to make the throttle lever pull down easier when you get half-way down or more. It is an assist to make the linkage work easier. By your own description, the governor weights possibly have exploded. That spring under the gas tank can be missing completely and the engine will still idle down slow and not run away by over revving. My opinion is based on what you have told us and 50 years of D-17 experience.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 9:15pm
gov wts and pins don't last forever
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2025 at 9:21pm
X3.....' happened to my D17 Series 2 a few years ago.
Things do wear out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterinMN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 9:13pm
I took my governor out and everything looked fine, weights are in place. I put it back together and now it won’t start because I think the timing is off. I followed the procedure outlined in the shop manual starting with finding TDC on the flywheel and positioning the distributor accordingly. No luck. Does the governor shaft and weights have to be put back in place the exact same way they were facing when I took them out? Does this matter? Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 10:30pm
If you mark where the rotor is exactly, remove the whole assembly as you did, reinstall it with the rotor back in the same place and it will fire right up.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 10:36pm
are you sure you are on tdc 1 not 180 off
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterinMN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2025 at 4:24am
According to the shop manual, Top dead center on the flywheel is the solid line with the F on top of it. The F is used for a timing light. The line should line up with the notch on the tractor. At this point the rotor should be pointing at 1 cylinder’s spark plug. It should work, but it’s not it is backfiring.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2025 at 5:37am
I'm betting your timing is 180 degrees off (like HudCo said).
Since it's a 4-stroke engine, the engine only fires every other revolution.
When you are approaching TDC on #1 cylinder (between the compression and power strokes) you will feel compression if you put your finger over the spark plug hole. When you feel compression, start watching for your timing mark again. When you get to the timing mark, you need to take the distributor out, reset the distributor to the #1 position, then reinstall the distributor.
Edited by WF owner - 11 Sep 2025 at 5:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2025 at 6:37am
TDC is the flywheel mark you are looking for thru the hole in the right side of the bell housing.   F or F-25 or F-30 isn't TDC.  The crankshaft pulley setscrew should be pointing dead straight down. Compression should be made on #1 when rotating the engine the way it normally turns. You could be on TDC #4  instead of TDC #1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterinMN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2025 at 7:42pm
got it figured out thank you for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:17pm
Would be nice to hear what it was....
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterinMN Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 12 minutes ago at 8:39am
I thought that F mark on flywheel was Top dead center but as Dr. Allis said it is not. I felt for compression in # 1 cylinder and then kept turning the flywheel until the other mark showed up and that is TDC. Fired right up.
My other over-revving issue I solved by shortening the rod that goes from the carb to the governor vertical shaft. I put it in a vise and made a offset bend in the rod, enough so it fit into the rod holds perfectly with engine off, throttle lever full open and carb throttle shaft pushed all the way back to 4:00 o clock position. I have no idea why the rod was too long in the first place because it is a original part as far as I know but then again who knows? Anyways it runs much better now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterinMN Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 56 minutes ago at 8:55am
My next step is trying to figure out why it leaks oil out of exhaust manifold on one of the cylinders, from what I’ve researched it could be piston rings or it could be valve seals or it could be head gasket.
Also, the power steering doesn’t work. Not sure where to start on that one. Winter is coming soon here in MN, and not sure how much I want to tear into this fall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 35 minutes ago at 8:16pm
Thanks
