D17 Series 2 Final Drive
ric44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ric44 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 2 Final Drive
    Posted: 05 Mar 2023 at 6:54pm
Just traded for this tractor and it runs like a champ with none of trans issues common to these tractors . It does however have gear noise coming from the final drives on both sides . The sound goes away when on a downhill grade . Was wondering if changing the lube and going to a heavier gear oil ( ie 85/140 ) might quiet it down some . I really don’t want to go to the trouble of swapping sides with the gearing . Any advice is appreciated .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 7:02pm
You think it is final drives, but in all honesty it is probably the ring and pinion under the seat. You can change the oil to whatever you want, but I doubt heavier oil will do anything for noise. This assumes of course, that everything has oil in it now.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2023 at 1:56pm
The final drives in my D-17 are a bit noisy. I attribute that to it's being used most of it's life by the P.O. pulling a 3 bottom plow on a large farm down in the valley.
I replaced the dirty old gear oil (they were not low) with Mobil 1 synthetic with no discernible change. It is most noticeable on the road in 4th gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ric44 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2023 at 2:03pm
I respect Dr Allis' opinion but I swear that the sound is more pronounced out toward the wheels . Anyway I think I will drain and change to heavier oil in the final drives .
Skip, W.Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skip, W.Pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2023 at 8:12pm
It's a little bit of work , go ahead and  remove both fenders and take it for a ride . I have been down this path with several D 17's over the years. It is amazing how the fenders will resonate noise. I believe you will then get a handle on where  the noise is. While the fenders are off it will give you a chance to do a little rust preventative work.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2023 at 12:14pm
Most of these final drives are seldom serviced. So changing the oil is good. I think I put 80-90 in my WD45 but 80-140 would work as well. Won't change the sound tho unless it is dry now. Great to clean up both those pans and install new gaskets.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2023 at 1:14pm
Could you switch sides/rotate the final drives, which would reverse the gears, use other side of the gears?
Edited by Dusty MI - 07 Mar 2023 at 1:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2023 at 8:26pm
that's what I did to my 45. The load side was flaked on the pinions. Replacing the flaking brgs and reversing them quieted them a lot.
