D17 series 1 diesel rebuild |
Page <12 |
JosephD17III
Joined: 16 Oct 2025 Location: Neosho, MO Points: 22 |
Posted: 07 Jan 2026 at 8:24pm |
I will continue the restoration, water damage is limited, i will work more on it tomorrow but it looks like this tractor ran just a few years ago, if it didn't have water damage or i had drained it sooner it would've been great but you live and learn. Number 1 5 and 6 have a little rust, number 2 is great and number 3 and 4 had alot of water and when it got cold in December it blew the sleeves, the pistons look great though lol. I'll need new valves and rods, the bottom of the rods were rusted bad,ideas on what needs repairs regarding that? Overall looks great crosshatching is chill prominent. No cracks, I've put stuff in the cylinders to break them loose.
Edited by JosephD17III - 07 Jan 2026 at 8:51pm |
JosephD17III
Posted: 07 Jan 2026 at 8:25pm |
I'm going to tear it down some more, more then likely fully and I'm gonna clean the block out and the head. Any ideas on that? I was thinking electrolysis??
Edited by JosephD17III - 07 Jan 2026 at 8:52pm |
Joined: 11 Sep 2009 Location: illinois Points: 90643 |
Posted: 07 Jan 2026 at 8:59pm |
electrolysis is great if you got the room / tank.. I have done that on smaller parts.. For larger cases ( blocks / trans / final drives) i spray them with oven cleaner, let it set 30 minutes and then high pressure water wash..
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4065 |
Posted: 07 Jan 2026 at 10:06pm |
you had better magna flux that head with every thing re moved , we just sawed a bad 262d cylinder head up with the band saw at the machine shop to see what the inside of the casting and what the water jacket looks like. and see what mine and the other guys can get away with , my machine shop is doing one for some one for else also. their will have to be welded and pinned. i was just at the machine shop this morning and forgot to take pictures the cylinder head cross sections. if their is any crack under the valve seats its done for
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8658 |
Posted: 08 Jan 2026 at 10:48am |
Joey,
These Allis experts are trying to save you time and money on this D17 Diesel tractor. Story : I had the idea I would like a Allis WD45 Diesel at one time about 10 years ago. I became friends with a member of this forum Don Bradley (rest his soul) He talked me down off the ledge several times about the Allis diesels. Back then he said you better have $5000 extra in your wallet to get a diesel engine correctly rebuilt. Now the price is double that! Not really surprising parts are hard to get! Experts on these are hard to find. Not trying to stop you on this project. But my guess is you may not be able to get your money back on this D17 diesel tractor. I just completed a little Allis CA. I bought it for $800 and probably put $4000 into it to have a light weight pulling tractor for fun. Regards, Chris and Cheryl Edited by Sugarmaker - 08 Jan 2026 at 10:49am |
JosephD17III
Posted: 08 Jan 2026 at 11:08am |
That would work too, thanks for the idea!
JosephD17III
Posted: 08 Jan 2026 at 11:13am |
Honestly I accepted it will be alot of money, I just want a orange and white tractor. I will magna flex the head and block to check it.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Posted: 08 Jan 2026 at 1:11pm |
There are a lot of orange tractors that will cost a ton less and be much more dependable.
The biggest problem with the Buda diesels was if you didn't have someone that knew what they were doing do the overhaul, you could spend a ton of money and have serious problems after the overhaul was done. This is not an engine to learn on!!!
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1333 |
Posted: 08 Jan 2026 at 1:40pm |
Jensales has a kit for a d262t, which would be for a d19 with turbo.
https://www.jensales.com/products/ep-915121-allis-buda-out-of-frame-overhaul-kit-buda-d262t.html If you look at the 8.25-1 kit for a gas d17 is $2500.. |
HudCo
Posted: 08 Jan 2026 at 4:10pm |
turbo piston are differant compression ratio if i am correct it is less so it would make it a pig
JosephD17III
Posted: 08 Jan 2026 at 7:46pm |
I don't know, I'd hate for the first tractor I bought to just be parts, the motor looks good but I'll take your guys experience over my excitement. I'll play with it some more, since it'll be fun. Plus I was going to do a full teardown anyway to clean it. is there a different motor that could be put in? What would the process be to put a d19 gasser in? Anyone got pics and stuff for that? I'd be fine with rebuilding a gas motor, also have another question. Why is the diesel 262 bad and gas 262 good?
RedHeeler79
Joined: 09 Sep 2023 Location: NE Kansas Points: 246 |
Posted: 08 Jan 2026 at 8:35pm |
It seems as though the gas 262 engine had a more reliable reputation. The relatively lower cylinder pressure (during the combustion event) of the gas engine vs the diesel engine, evidently has much less impact on the fire rings(which seal the uppermost diameter of the cylinder sleeve flange to the cylinder head, respective to the head gasket that “contains” them). The general theory is that the fire rings, of the factory gasket on the diesel engine, were made of soft enough material that they eventually gave way to the compression (cylinder pressure) and the cylinder sleeves were allowed to move up and down in their bores,in the engine block, enough to wear down the already inadequately small outside diameter ledge -think “jack-hammering”, that located them in the block deck at the correct height for adequate head gasket(fire ring) sealing. After prolonged operation, they would bounce up and down enough to wear out the ledge and “sink” into the block. This causes the infamous head gasket issues, and the major repairs required to actually fix the root cause of said head gasket failures, when overhauling the diesel 262. Sleeves need to have a standout (protrusion) of at least .002”, preferably .004” above the block deck. This is why several people have suggested that the machine work and resulting expense to correctly repair the block is extremely common and important. (Not to mention cylinder head cracking issues). Aftermarket fire rings of a harder material have been used, but it’s not widely known what the specific material or dimensions of these rings were made of. A former member of this forum, who manufactured and advocated for these improved fire rings, has passed away. So, the exact specifications of them may be lost. The gas 262 does not seem to suffer from this problem, regardless of hours on the engine. But, they also don’t seem to be easy to find overhaul parts for either.
Edited by RedHeeler79 - 08 Jan 2026 at 8:51pm |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5457 |
Posted: 08 Jan 2026 at 9:18pm |
That was an excellent explanation of its flaw. I have one, love farming with it, love the Buda sound out of the exhaust, love the fuel economy, good power, but I dread the day when I go down that road that your on….I may not be able to save it. A common problem folks didn’t do was let them warm up before working them and letting them cool down after they worked them. It’s really a shame the D17 didn’t get a 301 stuffed into it. What a monster that would have been!
Edited by AC720Man - 08 Jan 2026 at 9:20pm |
55allis
Posted: 09 Jan 2026 at 9:12am |
Just a thought, could someone leave the diesel pistons and swap the head to a gasser so you’d have a really high compression gasser?
HudCo
Posted: 09 Jan 2026 at 9:27am |
i have thought that myself for a d17 puller would think that the d19 piston would have to be used
Posted: 09 Jan 2026 at 9:44am |
Diesel pistons with .200" shaved off the top works good. Also be sure to use the thicker diesel head gasket when doing this.
Edited by DrAllis - 09 Jan 2026 at 12:43pm |
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1579 |
Posted: 09 Jan 2026 at 10:21am |
Read through this post
https://www.allischalmers.com/forum/looking-for-d19-diesel-engine-parts_topic204858.html |
JosephD17III
Posted: 10 Jan 2026 at 8:41am |
A 301 d17 would be a beast lol
JosephD17III
Posted: 10 Jan 2026 at 8:42am |
The fire rings on mine look new, would you know were to find those aftermarket ones though? Would his posts still be up somewhere?
Edited by JosephD17III - 10 Jan 2026 at 10:01am |
JosephD17III
Posted: 10 Jan 2026 at 4:49pm |
Well the sleeves have dropped, but i got a question. Do you guys think if someone made a custom multi layered head gasket it would still be fine? The tractor ran not to long ago i took the fuel filter off and it smelt of new diesel and looked good too, had newer filters in. Fuel lines are clean, don't know about fuel pump but all the lines into it are clean, injectors are a little dirty.
RedHeeler79
Posted: 10 Jan 2026 at 5:05pm |
Search for posts by MACK. Others on here have bought his fire rings and may be able to divulge some info on them. I’m not sure of the material used, but here’s a thread with some specific info for you.
https://www.allischalmers.com/forum/mack-fire-ring-questions_topic173226.html Edited by RedHeeler79 - 10 Jan 2026 at 5:12pm |
evan austin
Joined: 01 Jul 2021 Location: Gaston Indiana Points: 33 |
Posted: 10 Jan 2026 at 8:38pm |
There is a guy on youtube that put a 301 into a D17 diesel tractor. Look on there for Timothy Fluegel. It was a couple of years ago, they mostly use it for pulling but they had a 4 bottom plow on it a couple years ago too. He's got a D19 with a 433I in it too.
1955 WD45 Wide Front, 1946 WC, 1967 Gleaner E (AKA "Gretchen"), 1961 All Crop 72, 443 Baler
55allis
Posted: 10 Jan 2026 at 9:20pm |
![]() Here’s a snapshot of what MACK told me on my d262t. |
HudCo
Posted: 10 Jan 2026 at 9:56pm |
no
55allis
Posted: 18 Jan 2026 at 12:30am |
Happened to run across this site that has a in-frame kit for the naturally aspirated 262 .https://www.larsenlights.com/inframe-overhaul-kit-allis-262-diesel-naturally-aspirated
I have ordered led lights from them in the past and they are awesome!! Hope this helps. |
sampsonrepair
Joined: 07 Jan 2025 Location: Wisconsin US Points: 57 |
Posted: 26 Jan 2026 at 1:40pm |
If you are bound and determined to fix this tractor, Mark Pfouts is a great source for parts. But I would suggest saving yourself the time, aggravation, and grief by listening to the guys on here that are trying to tell you, DON'T. As the originator of the "looking for D19 parts" thread, I now know way more about these money pits (D262 engines) than I care to. My customer authorized the insane cost ceiling of $14,000 to repair his D262 in his rough D19. We gave up when the head was junk and we couldn't find another. We went the G262 (gas version of the same engine) route. These are a much more forgiving engine, but still insanely expensive to work on, hard to find, and hard to find parts for. The final product runs like a top, super smooth and responsive, but the rest of tractor is still rough, it needs 3rd gear work some day, and the power director drags really badly in neutral. The guy is super happy with it for some reason. Wish all my customers were like him! I wrote off a huge number of hours on the job, and am still ashamed of how high the final bill was. Unless you have deep pockets, great mechanical abilities, an uncommon level of attention to detail, like the tractor, plan to keep it forever, and don't mind getting three times the money into it that you will ever be able to sell it for, you will be $$$ ahead at this point to sell it for parts.
JosephD17III
Posted: 29 Jan 2026 at 11:13am |
I'm probably just gonna part it out, if yalo are looking for anything let me know.
sampsonrepair
Posted: 29 Jan 2026 at 12:05pm |
It's kind of sad anytime an old tractor needs to get parted. But in my business, I've slowly learned that when a tractor has been neglected for decades, that's often the only practical route.
JosephD17III
Posted: 30 Jan 2026 at 9:11am |
The even sadder part is if it had just had a can of the exhaust all I would've needed was custom fire rings, but it's just how the cookie crumbles, so im not to upset atheist iv got to own a orange tractor lol
Page <12 |
