D17 Seems to run out of gas going uphill?
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Seems to run out of gas going uphill?
    Posted: 01 Mar 2017 at 4:33am
My Series 1 D17 loses all power, and sometimes dies if heading uphill.  Is this a float problem?
Gas tank is full.
If I stop and wait a minute, it will line and and run again, and if I point its nose downhill, it will run fine.
It has a rebuilt carb on from Steve at B&B.  Below is the tag on the carb.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 4:37am
Any chance there might be something floating in your fuel tank that plugs the fuel line when you're heading uphill, then floats away when going downhill?
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 4:51am
Possible.  I coated the interior many years back, so a hunk of that could have flaked off.
I will look.
Also, looking back through my records, I am not sure where the carb came from, it is about 10 or 12 years old now.
- Roscoe
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 5:33am
open up the drain on the carb and make sure a steady flow of gas occurs. If so, then possibly a float adjustment issue. If not, plugged strainer or fuel blockage.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 7:48am
My D-10 would run good, first part of the morning, while on a caravan.
Then after a break it did not run well, I would have to use the choke.
I found that I had set the float wrong, it was too lean. When the gas was cool the D-10 ran fine, but when the day got rather hot, and the carb had heat soaked, is when I had troubles.
After readjusting the float, it runs fine.
Dusty
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 9:31am
Did you add an inline fuel filter? The common ones used in cars are not suitable for gravity systems, too much pressure drop. And when the tractor is going up hill with the carburetor mid or forward on the engine and the outlet of the tank at the rear the gravity head gets small.
Then the line could be nearly filled with varnish.
Gerald J.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 9:33am
I vote the float needs adjustment to allow more gas into bowl.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 9:38am
my wd would shut off when the govenor would kick it.  the previosos owner put a nail were for a cotter pin were the linkage hooks on.  when the governor would try to work, the nail would hit the side of the engine block and not let the linkage move.....tore the carb down I don't know how many times thinking some thing was wrong with it.....ugh, put a small cotter pin in and she was back up and running.....not sure if yours could have the same issue.
Edited by dt1050 - 01 Mar 2017 at 9:39am
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 10:34am
Your problem may very well be a carb float problem since you state that the tank is full.
However, I have found that, if the fuel tank is much less than half full, my D-17 will stall on a very steep hill. I have many of those steep hills here in my part of New York State.
My WD and WD-45 are not quite as prone to this and I attribute it to the different shape of the tanks.
On another note, My WD will lose oil pressure as well on a very steep hill even when the sump is full.
The D-17 is more tolerant in that respect.
Edited by Brian G. NY - 01 Mar 2017 at 10:37am
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 6:38pm
I unscrewed the sediment bulb on my d17 and found a piece of gasket material in the upper end of the metal piece the sediment bulb clips to. I thought I had good fuel flow, it really runs out now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 7:25pm
I'd do a comparative test on fuel flow:
1. test it on level ground vs
2. run the tractor up a hill until it dies, then re-test the fuel flow.
That'd tell you whether the issue is a problem before the carb or not. Could still be something other than fuel-related, but it might help to narrow things down a bit.
Good luck!
Dave
WC, CA, D14, WD45
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 10:03pm
I had this exact same issue on a Series II D-15 a couple years back. Only happened going uphill. It was the carb. Had it boiled out and that fixed everything. Been fine ever since. Hope that helps.
