D-17 Rock Shaft Arms and Spark Plug Question
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Rock Shaft Arms and Spark Plug Question
    Posted: 20 Feb 2011 at 6:10pm
Was there some kind of snap ring to hold the rock shaft arms in place on the D-17?  A tractor I purchased a year ago had them turned down one notch and it wouldn't lift the implement but about 2 inches off the ground.  Got them back up today to where they are supposed to be but there wasn't anything to hold them in.  Should there be?  Also does anyone know what is the best Autolite plug for the long reach heads on D-17's?  I have it written down somewhere but cant find it.
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 10:05pm
Autolite 295s are the plug you want, and yes a snap ring is used to hold the lift arm in place.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:58am
There should be a snap ring on both sides of each lift arm; total of four.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:36am
I think the last 295 autoliltes I bought were 3/8 reach. I like ngk b4 es   they are 3/4 reach.
Edited by mlpankey - 21 Feb 2011 at 12:27pm
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 1:21pm
check ebay. Sometimes you can find some new old stock AC 45XL spark plugs.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:39pm
I like the autolite 303 plugs, they last forever, not sure on the reach on them.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:49pm
I get cornfused - when did the D17 switch from short to the long plugs or was it vice versa.  Everytime I try to finger out which one I have I get a headache.........I have a '58 or '59 series I, so I think it should have the short plugs, right?
cheers,
Creek
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 6:45pm
I just had my lift arm off last week I had no snap rings there was just a roll pin inside.  I dont know about the snap rings. Is this only on newer 17's ?  Mine is a 61.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:07pm
I run long reach in both of these heads the 3 inch to 4inch heads .
Edited by mlpankey - 21 Feb 2011 at 7:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:11pm
Never mind my last post I just thought of what he was talking about. Just the arms themself. I was thinking of the shaft that the arm slids on to. Eric
