D17 Rear tires
JVON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVON Quote  Post ReplyReply Direct Link To This Post Topic: D17 Rear tires
    Posted: 03 May 2017 at 9:59pm
Hi all. I don't post much but read a lot on here. Slowly working on all the little details of my D17 and keep thinking ahead of items to replace or be prepared for. I currently have 16.9-28 on the rears that will need replaced. The original specs call for 14.9-28. If it was up to you, what size would you replace them with? I don't intend to farm with it, just play, parade and plow. I have a 4-14 slat bottom snap coupler for it as well. The 16.9 tires look almost too wide, but I could be all wrong. Just looking for opinions. Thanks! Jay
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:05pm
14.9 is the smallest size offered.  16.9 x 28 was the most common size for D17s.  Some of the later ones used 18.4 x 28.  I have 16.9 on both of mine and would not go smaller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:41pm
All 17's around here have 16.9's.Don't put them scrauny 14.9's on it.
JVON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVON Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:47pm
Next time I'm up at the farm I'll take a closer look. I bet the tires on it now are what it throwing me off. They have a lot of sidewall squish with a really small treadbar pattern. I had been thinking on staying with 16.9x28. I'll see if I remember to get a picture
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 4:28am
have 14.9 on my d14, gotta go bigger on a larger machine!! of course it depend on price for me
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 7:16am
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 9:02am
I have a brand new pair of Firestone 16.9x28 SAT 2  bias tires with the stickers still on, never mounted.   $950  would buy the pair, if that interests you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 10:18am
I am assuming all 17's came with the wider rim from factory which fits 16.9 nicely.Mounted on WD45 rims they have sidewall suck.Put a set of 45 rims on dads WD last time it got new rubber.It had 14.9's since early 60's and stock rims weren't ideal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 10:55am
I have a friend with a low hr D-17 IV and when he put new 16.9 x 28 rubber on it three years ago the rims were 13 inches wide. It had 16.9's on it....seems a little narrow to me, but that's what it was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 11:18am
That's a very good price. If I wasn't putting up a building, I'd grab those up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 11:20am
Digging through my D17 parts book it looks like the standard tire was 14.9 with 16.9 being optional and later on 18.4 being optional too.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 1:33pm
Jvon--I put a lot of tires on D17's over the years. 90 +% were 14.9x28's. Once in a while we came across a series 4 that had 16.9x28's on it. I never saw one with bigger tires than that unless someone had put 19.4x26 combine tires and rims on their tractor. The 14.9's will be fine on yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 2:43pm
17's were 1in wider than 45's.45's were 1in wider than WD's. By what Doc says I'll say WD=11in,45=12in & 17 13in. Measured WD & 45 once but I got CRS...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 3:09pm
yeah, nowadays they say to use a 15" rim for 16.9 tires
Driverdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 3:25pm
I have 16.9 tires on my D17 with 13 inch rims and they look and perform right. I personally would not want 14.9 on a D17....Dan
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 5:05pm
18.4X26 firestone F151's D17 puller
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 6:21pm
I've got 16.9's on mine and bought some 14.9's at auction awhile back. Was going to switch but those 14.9's look way narrow. I plan to continue w the 16.9's.
D17 Series 1
Allis B- 1939
Allis B- 1945
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 6:55pm
When the original 16.9 wore out dad put 18.4 bf Goodrich on and they cracked between the cleets within a year dealer wouldn't warranty unless dad got wider rims bought a new set 185 rims mounted new 18.4 on them she's now on her 5 set of shoes wouldn't put any thing less on one that was working now ,, I don't have any trailer Queen​s
redowns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redowns Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 7:16pm
I have three Series IV D17s and they all have 16.9x28 tires one we have had since 1970 it had the orignals then and they were 16.9. All of mine are serial numbers above 80,000. My Dad brought a new D17 in 1958 and it had the smaller tires. I think they were called 13x28 then. Later changed to 14.9x28. My rims are all 15 inch. I mearured them to make certain. They may have changed rim size at some point in the production.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 8:52pm
where did I measure from? Width is from inside of bead not outside of total rim.
JVON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVON Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 10:02pm
Shoot, I was at the farm tonight working on the front steering pedestal and forgot to measure the rims. I did look at the tires and thought it looked kinda goofy. I think the 16.9 tire will be the right size, it has to the tires I have on there now. The lugs are just an odd design. I really think that is what is throwing me off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redowns Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 11:30am
Steve, I did not measure properly. It would be 15 inches to the outside of the bead on the tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 1:26pm
I'd say by the time you add the curls at the bead to rim thickness etc you'd be really close to 15in on 13in rim.I think the 13in D17 rim had the rail bends ending right at the drop of the bend. The 45 sticks past bend a little and I can't remember if they use the block welded for support but the WD sticks a good bit beyond the bend and has a chunk of metal welded under the rail hook to the rim for support.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 8:26am
16.9-28's
Thanks & God Bless
Dennis
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 10:02am
Everywhere I have looked, I have only seen rims in widths of 11, 13, 15 inches. Now, it doesn't state exactly where they are measuring-total width or just inside the bead. I have seen many sources state that you want rim width to be as close to tire width as possible so 13.6 tires would be on 11" rim; 14.9 tires on 13" rim; 16.9 tires on 15" rim. My WD45 has 16.9s on it and it states right on the tires "on 15"rim".
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 1:02pm
My 1957 WD-45 had 12 inch inner width rear wheels with 14.9 x 28 tires on it from the Factory..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 10:35pm
No matter what the tire says,it doesn't make the rim something it isn't. I looked at dj's and OK tractor site and between them there were 11,12,13&15 in 28in rims.Something like a 180 would likely have 18.4 on a 15in rim.
