D17 rear spinout rim
MichaelT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MichaelT Quote  Post ReplyReply Direct Link To This Post Topic: D17 rear spinout rim
    Posted: 25 Jul 2025 at 6:55pm
Has anyone ever patched the rusted thru hole in my D17 spinout rim,
Is welding it a option or JB weld or has anyone got a suggestion
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 7:24pm
Best way I’ve found is to get a donor rim and cut out a good section then cut out bad area in rim and weld in good piece.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 7:40pm
Gary is correct but smaller rust thru holes can be patched with a small patch welded in after cutting the rusted area out. A good welder can make it nearly invisible to find. I had one repaired that was only 1”x1”.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 12:41pm
Welding is a great option.  Once the welding is complete, smooth with a flapper disk on an angle grinder.  Any imperfections may be filled with an epoxy and made smooth.  Most epoxies are easily smoothed with a wet finger.  Best wait until the epoxy begins to get to a plastic consistency.  Sand smooth once epoxy gets solid.  A good rust resistant primer and paint to top off the repair.  Make sure the paint is COMPLETELY dry, before mounting the tube and tire.
