D17 rear main seal ?
Kevin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Topic: D17 rear main seal ?
    Posted: 27 Apr 2010 at 10:53am
how do the little E or F shape gaskets go under the rear main cap ?..I've searched but all I can find is under the rear main bearing cap. I didnt see any on taking apart.. does the gaskets go between the felt seal??
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 11:10am
Yes, the F shaped gaskets go under the rear main cap, they go around the felt seal or as you say between the felt seal halves.  The last guy to have it apart may not have had the small gaskets or may not have know where they go.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 11:24am
so how do they go in.. i've turned them every direction.. F. Does the top of the F face the crank??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 2:41pm
just figured out that the after market gasket set is'nt correct.. the F gaskets are wrong,also pulled out the new rear main seal because the felt doesn't look thick enough to seal properly..I just dont trust them... Just ordered from Dean Ag..to be on the safe side.. I would hate to have it leak and have to pull engine again...
This page was generated in 0.445 seconds.
