D17 Question |
AC ORANGE
Topic: D17 QuestionPosted: 31 Oct 2025 at 7:58pm |
Will a Series IV D17 rear portion of the tractor bolt up to the earlier series? If so where is the best place to split, bell housing?
Reason I’m asking is I want to take the improved rear of a series IV and install to an earlier series narrow front. The narrow front ends are difficult to find in my area in a series IV. Is it easier to swap out front ends, from a wide front to a narrow if they are the same across series? Thanks Edited by AC ORANGE - 31 Oct 2025 at 8:11pm |
Posted: 31 Oct 2025 at 11:27pm |
On a good day, at my age, I could remove a series 4 wide front axle and replace it with a NF pedestal is under 2 hours. That is the only way to go in your situation.
AC ORANGE
Posted: 01 Nov 2025 at 10:54am |
That makes sense. Reason I’m asking is I have an opportunity to purchase a non-running wide front series IV and a running narrow front earlier series.
Posted: 01 Nov 2025 at 4:59pm |
Depending on the serial number/age of the narrow front pedestal, it may fit. Oldest versions used 1/2" bolts and later (way before a series 4) used 5/8" hardware.
Simon2
Posted: 01 Nov 2025 at 7:59pm |
Dr Allis
Is the 1/2” to 5/8” bolts the only difference? Can the 1/2” holes be drilled in pedestal for the 5/8 bolts? |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 659 |
Posted: 01 Nov 2025 at 8:26pm |
Might be a option to put 1/2 to 5/8 bushings in the pedistal
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
8070nc
Posted: 01 Nov 2025 at 8:27pm |
Sorry. Got it backwards.
1984 80780
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1165 |
Posted: 01 Nov 2025 at 9:18pm |
I just did the other way around…
Put an early d17 wide front on a series 3. Drilled the holes from 1/2” to 5/8” and will have to cut the rear bracket off and weld it in a different position. |
