D17 Question
AC ORANGE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC ORANGE Quote  Post ReplyReply Direct Link To This Post Topic: D17 Question
    Posted: 31 Oct 2025 at 7:58pm
Will a Series IV D17 rear portion of the tractor bolt up to the earlier series? If so where is the best place to split, bell housing?
Reason I’m asking is I want to take the improved rear of a series IV and install to an earlier series narrow front. The narrow front ends are difficult to find in my area in a series IV.
Is it easier to swap out front ends, from a wide front to a narrow if they are the same across series?
Thanks
Edited by AC ORANGE - 31 Oct 2025 at 8:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2025 at 11:27pm
On a good day, at my age, I could remove a series 4 wide front axle and replace it with a NF pedestal is under 2 hours. That is the only way to go in your situation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC ORANGE Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2025 at 10:54am
That makes sense. Reason I’m asking is I have an opportunity to purchase a non-running wide front series IV and a running narrow front earlier series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2025 at 4:59pm
Depending on the serial number/age of the narrow front pedestal, it may fit. Oldest versions used 1/2" bolts and later (way before a series 4) used 5/8" hardware.
Simon2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Simon2 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2025 at 7:59pm
Dr Allis
Is the 1/2” to 5/8” bolts the only difference?
Can the 1/2” holes be drilled in pedestal for the 5/8 bolts?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2025 at 8:26pm
Might be a option to put 1/2 to 5/8 bushings in the pedistal
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2025 at 8:27pm
Sorry. Got it backwards.
1984 80780
1957 D14
616 tractor
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2025 at 9:18pm
I just did the other way around…
Put an early d17 wide front on a series 3.
Drilled the holes from 1/2” to 5/8” and will have to cut the rear bracket off and weld it in a different position.
