D17 Question
acwd45ca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwd45ca Quote  Post ReplyReply Direct Link To This Post Topic: D17 Question
    Posted: 24 Jan 2020 at 3:52pm
I am restoring an early D17 Serial # 3017. Would this tractor battery hookup be a negative ground or still a positive ground. It still has the original generator on it.
Rod Folkert
Rod Folkert
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 3:57pm
positive ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 3:59pm
All Allis tractors with a generator were positive ground from the Factory. That doesn't mean someone might not have changed it, but that's what it was when new. If the wire on the ignition coil that goes to the distributor is +, that's what the battery should be for ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwd45ca Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 5:26pm
Thanks for your help. Much appreciated.
Rod Folkert
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwd45ca Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 5:27pm
Thanks for your help. I appreciate it.
RF
Rod Folkert
