D-17 Question and Parts Needed
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Question and Parts Needed
    Posted: 17 Apr 2010 at 4:24pm
When checking the transmission oil on a 1959 D-17, what is the proper way to do it.  To the right of the gear shift is a breather cap in which the manual calls the "transmission filler".  The books says to fill to the full mark on gauge.  Well that's my problem, it is just a breater cap with no dipstick.  Am I missing a dipstick?  If not, how do I know when it is full?
Second:  if anyone would have any of these parts for sale or available for a D-17 let me know:
1.  The two pins that hold the yolk and drawbar up.
2.  A pto guard.
3.  An hydraulic oil dipstick assembly (mine has the breather but is missing the dipstick).
Tks.
Edited by Steve-Ohio - 17 Apr 2010 at 4:25pm
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 4:33pm
Steve,
A couple of top link pins form TSC work good for holding the draw bar bail, or yoke,  to the brackets, unless you are shhoting for perfect originality.
Adam
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 4:33pm
Yes you are missing the dipstick. If i remember right (the tractor is not here to look at) the breather cap is for the hydraulic oil. There is a screw on dipstick for the transmission. One will mount just a little bit further foreward that is your hydraulics.
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 5:58pm
Yeah, I  know I am missing the hydraulic oil dipstic that is on a breather.  But the transmission filler breather just to the right of the gear shift, should that have a dip stick?
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 8:06pm
Steve, mine has the tranny breather om the right front corner of the shifter cover with a dipstick. Also in front of the transmission cover on the left is hex plug also with a dipstick for the intermediate chamber with the pto/ power director gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 8:14pm
Yes, that should have a dipstick also.  I don't know if it is the same, but I have a D17 series 4.  If they are the same I can measure my dipstick from the top down so you can use something in the meantime for a makeshift dipstick until you find one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 8:16pm
My 1958 D17 has a dipstick on both the trans breather and on the torque tube RH side for the hydraulics/Power Director.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 8:29pm
Steve, from the top of the hole in the shifter cover to the oil should be 8 7/8" approx. for full.
Gary(OR) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 11:48pm
So to summarize, on the early models, the PD cap/check is to the left front of the shifter, transmission to the right of the shifter, hydraulics below the fuel tank, right side of torque tube.....all 3 should have a built in dipstick.
I've got a spare hydraulic breather/dipstick, nice condition....send a pm or e-mail if interested. Thanks
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 3:15pm
$10.00 pins
$40.00 PTO cover
$45.00 breather and dip stick
785-353-2392
Thanks
