D17 Puller + Power Director |
BrianC,Ont ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Belleville Ont Points: 903 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Oct 2011 at 9:49pm |
I am going to build a V8 D17 puller this winter. Has anyone retained the PD with a higher hp application. It will be a mild big block Chev. I was also thinking of putting in a 3 speed auto and eliminating the PD. Trying to figure out if I want a long wheelbase with the auto trans configureation. There is a guy that pulls with us that has a Chev 350/ Allison auto out of a school bus in a 300 Farmall, and a 6 cyl
Ford mated to the torque tube on another 300 Farmall. The long tractor looks cool, but takes up precious space on the trailer. Brian |
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22059 |
Take it out !!! V8 high rpm's may make it explode !!
Lester ![]() Orange Level ![]() Joined: 08 Jan 2010 Location: Indiana Points: 521 |
Putting a D-19 PD that has one more disc in high and low range will help a lot. I did that in my 175 with a turbo in it. DrAllis is right, do not make too many rpms.
At 3000 rpms you may loose both legs. Could also loose 2 of something else. MACK
KGood ![]() Orange Level ![]() ![]() Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
So what comes apart in the PD? Do the shims fly out or the keys on the little pins come off? Or housing split open?
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Yes!
The PD is made of cast iron. The cast iron spinning around at Hi RPMs Will come apart(exploid). I would not want to turn one over 2800 at the most.
Better to be safe than sorry.
Have saw 190s explode when guys thought they could pull start them. MACK
Thats to bad,it sure would be nice to have going against bigger cube tractors. I guess I didn't notice it's cast iron.
BobHnwO ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Pressure plate exploded in my 55 chevy one time,NASTY!!!
