D-17 Power Steering - Adding Fluid
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Power Steering - Adding Fluid
    Posted: 14 Sep 2010 at 9:10am
When I first got my D-17 (series II) I checked and topped off all fluids. It seems odd to me how the fluid is checked and filled in the power steering. I pulled the distributer and brought the fluid up to within 1-5/8" of the top of the distributer opening as directed in the repair manual. The operator's manual is a little vague on this.  When I had to work on my distributer recently, I noticed the fluid level was down so I put in some more to bring it back up to the recommended level. It took maybe a third of a cup. I know for a fact that a neighbor farmer has always removed the vent cap at the front bolster behind the grill to add fluid to his D-17 which apparently leaks a bit. How do all of you other D-17 owners maintain fluid levels in you P.S. systems?
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 9:13am
Behind the front grill screen on my IV.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 9:15am
The PS resorviors on the D-series are filled in front of the radiators. The front bolster houses the steering mechanism and is used as the reservior.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 9:15am
Behind the grille screen
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 9:18am
Brian, The fill port on a D-17 is located behind the grill, in front of the radiator.
Clean all dirt away from the area before opening.
There is a breather looks like a small cylinder with a nut on the bottom.  Remove this and check  the fluid level.
The front support is  the power steering oil sump.  Keep filled to 5/8" above top of segment gear.
No need to remove the  distributor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 11:04am
OK, I get it now! I went back to my operator's manual and read just what Clay said.
When I re-read the part about the  "Distributer Drive Housing,"  I see what they mean;
for those tractors with power steering the dist. drive housing should contain fluid within 1-5/8" from top of housing. Manual says check every 300 hours of operation. It appears that the oil in here may be  leaking out and I wonder if this is the cause of the wear on my distributer gear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 12:19pm
Yup.....just pack the cavity with gun grease instead.
