|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| D17 Power Director |
| Post Reply   |
| geb   Silver Level   Joined: 29 Sep 2009 Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Topic: D17 Power Director Posted: 22 Feb 2010 at 9:14am |
    Last Summer I bought a D17 and the owner told me upfront the PD didn't work right. He had it "blocked" in high side with the control lever tied in position. The man was very honest and I have no complaints with him. After getting the tractor home I found there was not enough fluid in the PD to touch the dipstick. I filled it to the full mark and untied the PD lever and moved it back. Well now the tractor won't move in low nor high. I just put the tractor under the shelter and I'm now getting ready to work on it. Any suggections? Is the PD disk manually moved from low to hi or is is hydraulic? Also I have a PD clutch pack out of a 180 and can anyone tell me if the clutches or anything else might exchange and be usable in the D17 PD. Any help would be appreciated. Thanx | |
| Gary (e.c.mo)   Silver Level     Joined: 01 Oct 2009 Location: Middletown Points: 51 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Feb 2010 at 9:50am |
   geb  Check the PD handle and make sure the set screw is tight on the shaft going inside the housing. I have seen tractors that did NOT have low side and all was wrong was the shifter handle was loose on the shaft.Set screw is at bottom of handle. Good luck.  Gary
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
