D17 power director hanging up |
Chris (swIA) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Prescott, IA Points: 319 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Apr 2011 at 3:57pm |
My 17 is hanging up occasionally when I try to pull it into the low side. The hogh side work fine. If you go to high a couple of times it will go into low. it doesn't slip when it is in low. I have the side cover off and there is nothing obviously wrong. Has anyone had this problem?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21070 |
My guess would be the neutral catch mechanism is getting caught somehow when pulling the lever back.
I had the side cover off and it would still catch. It has to be in the low side clutch pack. It worked fine and started doing it when I was rotobaling last year. I looked for loose pins but didn't find one. Is there a snap ring holding the drive hubs that could have broken?
Could be a broken plate stacking onto another plate. MACK
