d-17 pilot bearing ?? |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 474 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jan 2019 at 6:15pm |
Does the new pilot bearing simply slide onto the end of the trans. shaft, & the crank rides against it once the engine uis in place ?? There wasn't one on it when we removed the engine. thanks, keith so. va.
d17brown ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: farley iowa Points: 1721 |
pilot bearing should go in the flywheel, than the clutch shaft should slide into the pilot bearing
phil
