D17 Oiling System
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: D17 Oiling System
    Posted: 14 Sep 2010 at 10:43am
Can you use the oiling setup from a later engine on an early engine. I have an oil pump that is after serial # 24001 that I want to put in an early block. I know that I have to change the filter adapter, but is there any other changes. Also any good used pumps for sale.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 6:15pm
Bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 6:29pm
I don't think so, but I don't know for sure. Early style is a bypass type filter system. The later all the oil goes through the filter.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 6:38pm
Brian
The pump will likely work: the oil filter and lines will not. The later, full-flow system uses 1/2" or so lines that come from the block, to the filter and then right back into the engine. Means much larger ports in block that aren't there in the older style. But it also means that ALL oil flowing through the engine is filtered FIRST.
The old block uses 1/8" lines to bleed a little oil into the filter, and a "tee" runs a little more up to the head to feed the rockers. Behind the filter mount on this one, is a passage way drilled to return the oil coming out of the filter back to the engine. Only a little oil is being filtered at any one time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 8:44pm
You can use the newer style oil pump as-is IF you have the same tooth count on the gear that mates with the camshaft. You can also convert your old style block over to "full-flow" oiling/filtering system if you have the engine torn down. Takes some drilling and tapping and plugging of certain holes, but it can be done (i've done a dozen or so over the years).
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 6:34am
As Dr. Allis says it can be done, but I have heard of  a couple cases where the  people did not know what they were doing and ruined the motor.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 6:36am
I have a D-17 oil pump [ newer style w/ bypass on it] that I do not need. I think it is OK condition
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 12:26pm
Dr Allis; The motor has been rebuildt and is almost together. Is there any thing intrenal that has to be drilled. I will take the old style bypass and drill and tap the plug for the drain back to the pan.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 1:13pm
Is there any other difference with the new style pump other than the full flow thingy?  More flow and/or pressure?
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 4:21pm
You have to drill and tap the block in the horizontal upper passage and drill/tap/plug the drain holes down below and drill/tap/plug the vertical passage to block oil flow between the upper and lower passages. I did an old D17 once in chassis and never had a problem, BUT you have to be really, really, really careful about not getting cast iron cuttings where they don't belong or there will be an immediate failure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 11:28am
Can some post a picture of the conversion, then I will have a better Idea when I go back to the machine shop.
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2010 at 10:46am
Does anyone have pictures of early and late engines with the pan off. Or any pics of an early block that was already converted. Trying to see the difference between the early and full flow oiling system. Dad took the full flow block out to the farm. I wont be able to get out there til next weekend, and the machine shop would like to get this engine out of his way. I hope to have this in the tractor for the last pull around here in Oct, on Thanksgiving weekend.
Thank's Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2010 at 4:19pm
Just printed out the diagrams from agco parts books, Maybe we can get it done from these pics.
