d-17 loader
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: d-17 loader
    Posted: 28 Dec 2011 at 5:42am
..... got a question. i have a d-17 series 1 with a new idea trip bucket on it... would i b able to put a cylinder on the bucket? instead of having the trip bucket? how would hydrolics work? could i run a hose to the outlet in the back maybe???? thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 5:58am
What runs the lift cylinders now. The outlet in the back is only one way and is probably directly connected to the same port as the loader arms.
 For the best operation, you need a front mount pump that can handle both functions on the loader. Then you will need a reservoir and a set of 2 way valves to run the loader.
This page was generated in 1.502 seconds.
