D17 Larger Front Tires
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: D17 Larger Front Tires
    Posted: 04 Nov 2016 at 7:09pm
How wide can a guy go on the front of a D17 wide front? Currently have 6.50 on but would like to go to 7.50. Needing floatation for loader work.
AaronSEIA
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 7:29pm
I just looked at my D-17, with 500 loader, and it has 11L-15SL
Edited by Clay - 04 Nov 2016 at 7:34pm
Mosin9130 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mosin9130 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 7:39pm
I "upgraded" to 7.50 from 6.50 with no issues...tractor looks better in my opinion
'56 WD 45...'63 D15 II...'66 D17 IV
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 7:49pm
It looks like it would work, but would have very little clearance to the top of the spindle. Of course, the tires cost more...
AaronSEIA
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 8:19pm
I went to 11L16 on my MF-135 and then my 4020. Now my 4020 using those rims has 11.00-16 that are taller than the 11L16. I had to go to 8" wide rims that had additional offset to keep the tires from rubbing on the tops of the spindles. I think from the originals that were small offset that I went to an additional 2-1/2" offset. Its been nearly 20 years since I did that. The 11L16 were wagon tiers with not much tread. I found them a bad idea when cultivating or rotary hoeing because their little ribs didn't steer well. The 11.00-16 are four rib. I went to them because the tractors had a sturdy loader that put bit loads on the front tires and the originals were too narrow for the load. I also believe the wide tires are much better for the spindles because they don't make holes in plowed ground like the original 5.60 or 6.50 tires did and they didn't fall into furrows so much. I moved the 11L16 from the 135 to the 4020 the same time I moved the loader. The two tire changes on the 4020 raised the front axle about 4 inches and that actually leveled the tractor frame, but made climbing up to fill the gas tank more work because the top of the front tire went up about 8 inches. I'm not interested in changing back.
It may be that the present rims on the D17 are turned with the offset out so the rim centers are closer to the spindles which is a common condition planned to reduce twist on the spindle, and with the wider tires they may be turned around to move the rim centers out so the wider tires clear the tops of the spindles.
Gerald J.
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 9:07pm
I have 7.50's on my D17IV mounted on original rims. No problem.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 9:19pm
I have 7.50s on both of my D17s, no problems at all and looks better!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 10:34pm
Does anyone know where to get the wide 15" rims with a 5 bolt pattern??
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 10:38pm
Any tire store would probably be able to get them new.  If you want used, start looking at all the equipment in local farm scrap yards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 10:45pm
All I have..and ever see are 6 lug.
ALLIS EXPRESS!
This year:
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 11:47pm
Larger tires are fine but I would not turn the original rims out.  Had that on our D17w/ loader and loader lg round bales.  Had a couple of the rims break out at the lug holes.  Tut the replacements one the right way with no problem on heavy loads.
luckydogg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luckydogg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:43am
Old buick rims fit perfect. My father has ran bigger floatation tires forever on his d 17 with a dual  325 loader.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 11:21am
X2 on the old Buick rims and they are heavy duty, too!  Rick
This page was generated in 0.054 seconds.
