d17 IV hydraulics
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: d17 IV hydraulics
    Posted: 23 Mar 2012 at 5:54pm
Do I use dextron or universal fluid in the hydraulics systems? Thanks.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Longmeadow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:15pm
As the D-17 IV is essentially the same as a 170/175 I would use AC 821 or JD Hy-Guard or the Case/IH transmission fluid...which is a little lighter, but splashes better.. D-17 transmission is designed for "splash" lubrication. I would stay away from the stuff you mentioned. I have a 175 with over 7000 hours on it..use it daily for a chore tractor... no jumping out of gear no problems with the original power director clutch..et al.. in the final analysis you get what you pay for.  Oh, I forgot to add I run my 175 transmission fluid level quite a bit higher than factory spec typically using the Case/IH oil.
