D17 ignition coil
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Topic: D17 ignition coil
    Posted: 24 Aug 2024 at 10:33pm
D17 fried a coil a few days ago. Died in the yard and didn’t deal with it until the next day because I thought it ran out of gas. Turns out the coil was dead. Replaced it with one I had in stock from another tractor. Today I was picking up bales. Half throttle type work. After 2 hrs the coil goes dead again. I grabbed it and it was warm but no where near hot. You could hold it in your hand.
What do I need to start looking at to cure this recurring problem ?
Thanks
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 12:05am
Start by doing this:
Get a jumper wire, connect it from battery to coil power connection (bypass the ignition switch) and start it up.
Run it, and see if it eventually stalls.
If it doesn't, your failed coil is actually a failing RUN contact on the ignition switch.
They do fail... don't ask how I know...
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 6:25am
Get a test light and see if it has voltage at both small terminals.  If it does now, run it till it dies and check again.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 7:28am
6V coils or 12v coils ??? What is battery voltage ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:20am
AaronSEIA
Yes. Full light on pos. Flicker light on neg as you spin engine over and points open and close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:21am
12 volt coils. 12 volt battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 9:42am
i was just thinking out loud if the "NEW" coil could have been a 6V or needed an external resistor and you put it on the 12v.... and had too much voltage..
Could also just be a concidence that you have two "OLD" coils ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 3:13pm
Today it popped right off and ran a hour or so and the coil fizzled again. Put another coil on and kept going. Thinking it is probably all related to aged coils so far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 10:40am
I don't think it's aged coils. It could be aged wiring or possibly a bad Ignition switch as Dave mentioned. D17's also used those useless Ballast resistors as well. If your D17 has one of them things hanging on it, get rid of it and put a new 12V/3.0 Ohm internal resisted Coil on it. But, before you do that, better check the wiring on board that thing. Old wiring causes a lot of issues which make the Gremlins come out. It's one thing to burn up a couple old Coils, it sucks to burn up a new one!.....
Steve@B&B
This page was generated in 0.097 seconds.
