D17 Hydraulics
Regen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regen Quote  Post ReplyReply Direct Link To This Post Topic: D17 Hydraulics
    Posted: 18 May 2011 at 9:10am
Is the AC D17 hydraulics system an open or closed system with the transporter hook-up?
Also, what is the gallons per minute output of the hydraulic pump?
I have read my manuals and the I&T book, but I could not find this information.
Thanks in advance/
A/C D17 Series III LPG 42911 '62
Ford 851 LPG '59
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 9:13am
The first 17's through the series III had one system and the series IV had another system. In order for anybody to help, you would have to let people know what tractor you have.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 9:16am
The Series IV did not use a transport valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 9:59am
I guess this doesn't help. Tractor Date only lists the series IV.
Hydraulics:
Type:open
Capacity:9.75 gal [36.9 L]
Pressure:2000 psi [137.9 bar] (Series IV)
Valves:1
Valve flow:1.5 gpm [5.7 lpm] (Traction-Booster)
Total flow:10.5 gpm [39.7 lpm] (main pump Series IV)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 10:42am
Sorry about not giving all the information as I am still learning about the tractor.  The tractor is a Series III.
Ford 851 LPG '59
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 11:47am
You have the high pressure low volume system. The pump stops whenever you step on the clutch. If you're thinking about putting a loader on it, you really want to add a front mounted pump driven directly from the engine. The specs Charlie posted only apply to the series 4. Basically its the same system that was introduced on the WD tractor. It does not have an open center. Basically its power up gravity down with the control valve being in the belly of the tractor with the pump. Additional valves can be added, someone put a double valve on my series 1.
Edited by Brian Jasper co. Ia - 18 May 2011 at 11:52am
This page was generated in 0.289 seconds.
