D17 Hydraulic Problems
schuseby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schuseby Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2024 at 2:48pm
How does one change out that hose that is making the trans oil over flow into transmission. I did remove the breather steel ball. I own a D17 series III.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schuseby Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2024 at 2:50pm
I can’t find any videos to show how to replace or get at this hose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2024 at 5:39pm
The goal is to remove the lift arm housing. Drain the hydraulic oil at the drain plug directly down from the foot clutch pedal. About 3 gallons. Drain the transmission by removing the plug directly down from the seat cushion and above the drawbar. Holds 5+ gallons. Both drain plugs take an 1 1/8" wrench. Remove the complete seat/seat suspension. Remove 3 bolts that hold the PTO shaft in place and pull the PTO shaft out. About 3 ft long. Disconnect any steel lines to the rear left of the seat and remove the hydraulic coupler manifold. Lift the manifold, clamp a wrench on the hydraulic hose and turn the manifold CCWise to disconnect the hose. Remove the drawbar and bail. Remove both drawbar bail hanger brackets. Remove 9 bolts from the lift arm housing and get the gasket glue to let go and pry it off. Weighs 150+ lbs. A small cherry picker can be your friend. Internal hydraulic lift arm cylinder rod will pull out of the barrel. Replace hose (5000 psi quality) AND the packing seals inside the barrel. Use lots of light grease when assembling the rod back into the new packing. When I was much younger I could do this in 4 to 6 hrs time.
Edited by DrAllis - 24 Sep 2024 at 8:07pm
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2024 at 8:20pm
Also; take a close look at the cylinder bore while apart.  If there's alot of scuffing or evidence of some debris leaving long scoring marks, remove and hone it (or have it honed)
