D-17 Hard starting |
Post Reply |
Neal (scMN)
Silver Level Joined: 11 Sep 2009 Location: Truman, MN Points: 196 |
Posted: 18 Aug 2010 at 11:10pm |
My D-17 series 3 will not start if it sits out in the rain. It seems to get wet very easy. Is there something I can spray of the distributor cap? Or is the problem elsewhere? If it won't start and it has stopped raining I can remove the distributor cap and let it sit open for about 1/2 hour and then put it back on and get it started. My daughters wedding is coming up and I am pulling the wedding party around town on a hay ride and don't want to be delay if it won't start.
Eldon (WA)
Orange Level Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Hey Neal....long time no hear from ya! I'd try the obvious first....new distributor cap. If that don't work, park it in the garage and leave the car out in the rain LOL! Congrats on the new SIL!
ALLIS EXPRESS!
This year: |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7379 |
Its possible you have a cracked distributor cap. A new one could solve the problem. However, in the past I have used WD40 inside a distributor cap to get an old Ford pick up going after a heavy rain. |
Jeff Z. NY
Orange Level Joined: 11 Sep 2009 Points: 7326 |
http://www.gunk.com/CAT_M1306.asp
gcalent
Bronze Level Joined: 19 May 2010 Location: Willards, Md Points: 179 |
I would replace the cap, also I don`t know the condition of your wires. The cover on the plug wires will break down over time and bleed voltage because moisture will get through. I would replace the wires unless you know for sure they are in good condition. I leave my D17 outside in the rain at times and don`t have a starting problem. When you pull the cap up when it won`t start do you actualy see moisture inside, if so the cap may be all you need.
Pullin With AC
Matt MN
Orange Level Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Yes I believe it is time for a tune-up. I would do points and condensor and cap and wires Maybe even plugs.
You dont want a dead tractor on the BIG day!! |
Post Reply | |
