D17 gas vs. diesel |
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1770 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Nov 2018 at 11:02pm |
i use a wd45 an a d17; on 60 acres. works fine; by rights should be farming 160 but o well' work ground with the 17 an plant with the wd; the gas tractor has more power' an your not at the head land working on it.
Edited by dawntreader74 - 26 Nov 2018 at 11:05pm |
littlemarv ![]() Orange Level ![]() Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
That's something to consider too. Big brother has a D-14, and if junior helps out to boot, we can cover a lot of ground, literally. Maybe I should save my money for seed and fertilizer!
The main attraction to the D-17 for me is two fold. The hi low, and the seat is ahead of the axle. More gears and more operator comfort with less catapult!
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Growing up, we had a WD45 and a CA. We farmed 120 acres, 90 tillable. We had corn hay and wheat. The wheat was a hold over from the horses.
Those two tractors had a lot of hours on em but were never down in the 20 years I was with them. Just normal little things (usually carelessness from the operator) and the normal maintenance. We milked 25 cows, raised chickens, pigs and horses. With what you have already, you have PLENTY of tractors to work 40 acres. Granted the WD has less horse than the 45, but it really wouldn't matter. If you were to add a D-17 or WD45 to the fold, you'd have more than enough to handle whatever the Good Lord can throw at you. I've got a D-17 gas that didn't even get started this year. But then, I'm not farmin either......just hobby farmin. Playing mostly,,,,,I'm too old to be working honestly any more.. ![]() |
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Since you mention up to 40 acres someday, and have plenty of smaller equipment now, may want to consider a decent D15II SC gas tractor that you can add a 3-pt. adaptor to. This would get you started and a decent D15II can be had for 2500-3000.00.Easy enough to sell later as you expand but bettin you would keep it. I own 25 acres with 100 additional attached to mine on lease for running beef. After getting my seeding done and established with a D15II when I bought the place, still reach for one of the D15 units 95% of the time. I have some trees and the D15's are easy to maneuver but I have no hills to speak of. D17IV gas w/ factory 3-pt. was used this year for cultipacking winter wheat/oats/rye and she has now had a whopping 25-30 hours put on her over the last five years. Wanted to keep her lubed and she played with a 1350# Brillion.
Just be careful as it is addicting when one A-C is brought home. I have plenty that just never get used like I thought I would, including a 185, 190XT and a D17DIV as the D15's still get it done including just putting out round bales tonight.
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
D-17 gas, for cost control. Plus it is quieter.
How about a 175 diesel. Parts are easy for the Perkins. |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Series 4 Gas would last you a long time and be the most versatile with heavy duty 3 point.
Charlie
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2306 |
Don,t know how much time you have to farm, but people used to farm a half section with a D 17, would think 40 acres would be easy with a D 17.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8534 |
Marv,
You have several other tractors that can do some of the light work on your 40 acres too. The D17 would be the big dog. I like the Series I that I have with gas engine. I helped farm about 120 acres for years with two WD45's. The D17 would have been a nice upgrade and as you mention the equipment fits. I hope you can start to work the 40 acres! Regards, Chris
Like the Dr. says or if he did an engine transplant. My neighbor put a 433i out of a combine in a D17 that produced 80hp on the dyno.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21967 |
To Ranse: A D-17 gas had 53 HP and the diesel had 51 HP at the PTO as tested by Nebraska Test in Fall of 1957. Your friend forgot to mention the 80 HP version must have had a turbocharger on it ?? even at that, a D-19 turbo diesel was only 66 HP and was known for blowing head gaskets. I'm afraid your friend didn't know what he was talking about.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3091 |
Your experience brings up another good point when you own only one tractor it needs to be something that is easily repaired and parts are easily found.
Ranse ![]() Orange Level ![]() ![]() Joined: 11 Mar 2016 Location: Tennessee Points: 775 |
Are you guys saying a gas powered D17 would have more horsepower than a diesel D17? I've never been on a diesel, but I figured it would be the other way around. I once had a guy tell me his diesel D17 had 80 hp.
I love my D17D, but it cracked the head recently. Unless you have a check book that can tolerate these unexpected expenses, find a good gas powered tractor.
JBergie ![]() Silver Level ![]() ![]() Joined: 14 Oct 2018 Location: Minnesota Points: 54 |
Tractors around here (MN/WI) seem to be a little higher priced here because of the shorter 'working' field season (or so I've been told by a few farmers). Regardless, I'm in the exact same boat- searching for a D17. *Missed out on a good one up for auction that went for $2,200- it was a great deal because of all the work that had been done on it. |
I guess I think all Allis stuff is high around here... I pert near shed a tear when I see other guys haul a tractor with attachments home for a couple hundred dollars.
This is all good information. I was worried about this turning into a "what kind of oil is best" kind of topic. A 190 would be sweet as well. But here is my train of thought. I have smaller equipment that we use for a food plot. Three bottom plow, 8' disk and drag, grain drill, and two row corn planter. I plan on starting with a 10 acre field and see where it goes from there. Can I farm up to 40 acres with a WD and that size equipment? Sure, but its going to equal a ton of seat time. I don't know. It may not ever even happen. If I would get a 190 I would have to get all bigger tillage equipment to go with. I just don't know. Awhile back I looked into the inputs, and even without having to pay rent, it seems like a fellow would do a little better than breaking even in a good year? Sometimes I think of setting up a small farm for a tax shelter of sorts? This is all just supposition, I'm mostly looking for ideas and advice.
7060 ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
On that kind of budget you can get a decent 7000 series and have a lot more tractor, but I know that wasn’t the question.
Joe(OH) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 995 |
Buy yourself a nice 190 XT diesel and be done. D-17 is a fine tractor, but a 190 can be had for a similar price.
Life is simpler when you plow around the stump.
Tractors must be high in your part of the World,if I had $4000 to buy a tractor that'd be the only one I had to farm with it wouldn't be for a series I D17.
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
For 40 acres, you may want to bump up your hp a little. The d17 will be on the light size for most more modern equipment. These tractors are 50 years old now so I don’t like to pull the guts out of them, maybe help keep them around a little longer. If you stay determined on a d17, I’d go for a series 4 w/3pt and a gasser. Just my opinion.
And those numbers are at 100% load, which would be like plowing.
Using those numbers on fuel usage the gas at 4.5gph x $2.09 gas = $9.41 per hour to run
The diesel at 3.7gph x $2.97 farm fuel = $10.99 per hour to run The gas would have a few more hp, start easier, run over $1.50 an hour cheaper and be easier to find parts for in my opinion. |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
I have a series 4 diesel, wide front-3 point. You could not get it away from me. In the 35 years I have ownd it, 1 injector pump/injector clean up and 1 head gasket. The only reason I would buy a gasser would be for ease of starting in below zero weather.
Nebraska Test shows the following fuel consumption at varying HP levels: Gas uses 4.5 GPH @ 53 HP--- Diesel used 3.7 GPH @ 51 HP. Gas uses 1.8 GPH @ 2 HP--- Diesel uses 1.4 GPH @ 2 HP. Gas uses 2.9 GPH @ 26 HP--- Diesel uses 2.1 GPH @ 24 HP. There's no doubt diesel uses less fuel, but there's also an injection pump and injectors to maintain versus spark plugs and ignition points on a gasser. Back in their day, diesel fuel was 10 cents per gal and gas was 15 cents. Not so any more.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
I'd buy s GAS tractor, PLEASE leave don't get one of them old 262 Diesels and farm with it. I rebuild them a lot and they eat dollars by the truck load.
I would like to add a D17 to my collection. Ultimately I hope to be crop farming up to a whopping 40 acres someday. I know, I know, pretty much gardening compared to todays mega farms. But, its going to be my little hobby farm. What would be better, a gas or a diesel? I know the diesels had problems with headgaskets and liner heights, has there ever been a solid solution for that. I have no problem fixing the engine on one. But on such small scale farming, does the economy and lugging power of the diesel outway the higher cost? Just spitballing here, so I can figure out what I should be looking for when I start my next treasure hunt. Lord knows I can't buy anything turn key, I always have to find one with something wrong with it to get it down into my price range. My cousin had a Series 1 with a loader and snowblower and a really nice homemade cab on it that needed a clutch. I told him I would buy it if he didn't get any bites on Craigslist. He put an ad up, asking like $4000 for it, some guy showed up the next day and plunked down the cash. Yikes.
