D17 gas tank center strap question |
JBrownIndiana
Joined: 13 Sep 2009 Location: Jasonville IN Points: 110 |
Topic: D17 gas tank center strap questionPosted: 13 Nov 2016 at 3:10pm |
Did the early D17s have a center gas tank strap? I just realized the other day that my 1958 D17 didn't have one on it. I'm also in need of a center strap and fuel gauge for my D17 series 4, it's a little on the rotten side, and fuel gauge is shot. Thanks in advance!
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 13 Nov 2016 at 4:16pm |
If you are referring to the strap that goes from front to back, attaching at the steering shaft area, and then also up front on the battery tray?
I am not aware that any of the D17s had anything different, except the LPG models of course. I did a quick check of the parts books, and there is no mention of a serial break, or any other mounting options.
Still in use:
Bill Deppe/AC Salvag
Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Posted: 13 Nov 2016 at 5:01pm |
Believe the early D17 tanks were mounted like the WD's with a angle piece instead of two studs at the bottom
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 13 Nov 2016 at 5:09pm |
Angle peice two bolts on the bottom and a strap that goes from the bottom left across the top of the tank to the right side with two regular flat head screws fine pitch thread that hold the strap down. The strap crosses the tank right near the end of the two hood side covers if the strap is just a little too far forward the side cover will not latch. I have a d17 from the first year of production and have removed the gas tank a few times before I got it cleaned and lined.
Edited by Dan73 - 13 Nov 2016 at 5:11pm |
Posted: 13 Nov 2016 at 5:49pm |
Oldest D-17's didn't have the front to back strap. There was a kit to be able to install that strap, that consisted of a u-clamp that went around the steering column tube. The factory installed version had a socket welded to the steering column for an attachment point, instead of the U-clamp. S/n 28,607 was the break point for the add-on strap and the factory installed strap. I think the plan was this....if your fuel tank failed/cracked on the bottom, you replaced the tank and added this extra strap to secure it better from vibration. I've seen a handful of old gas tractors that had a much newer painted fuel tank and this added on u-clamp secured strap.
JBrownIndiana
Posted: 13 Nov 2016 at 8:07pm |
Thanks for the heads up, that gave me a better understanding of the situation. I had to fix the tank on the 58, and had the tank on the series 4 cleaned out. Guess I will try to get a replacement for the 4, and leave the 58 as it is.
Matt (Jordan,MN)
Joined: 12 Sep 2009 Location: Jordan, MN Points: 3810 |
Posted: 14 Nov 2016 at 12:45am |
I have a NOS strap I will sell. Send me a PM. Thanks Matt
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
JBrownIndiana
Posted: 14 Nov 2016 at 10:25pm |
Pm sent, thanks!
JBrownIndiana
Posted: 15 Nov 2016 at 4:15pm |
Sent PM, did you get it ok Matt?
Gary(OR)
Posted: 15 Nov 2016 at 10:06pm |
I've got a good used one I'd sell. Can get a pic if interested...
Edited by Gary(OR) - 15 Nov 2016 at 10:09pm |
